EE wifi
Parasurfer49
I have contacted EE to stop the EE wifi hot-spot that others use to piggy back on my router. But it's not been stopped 3x. I tried everything. Even logging on to the router 192.168.1.254 and disabling WIFI. But that's not stopping the EE WIFI hot-spot on my router. It's a very strong signal that anyone can use on my router. I work in the government and need not only security but all available network. I heard a firmware update is behind this. It wasn't on older BT routers. Can you help please?
17 REPLIES 17
@Parasurfer49  You could always get your own router.
Also I can't receive the American news channels and international news channels because I think the Elmley moor tv transmitter isn't broadcasting them or nor not strongly enough. How can I fix this?
Either:
  • Wait a day or 2, OR
  • Opt In & then Opt Out. That's the state of mine & EE WiFi is not broadcast from my SH+, OR
  • Both.
I don't see what EE BB has to with OTA Freeview.
Ok. I'll give it a while. Thanks for your expert valuable advice.
I have an EE TV Antenna in the loft. Gets the best reception. Better than broadband.
Also someone has been war driving and crashed both my new and old pcs. I can't start them up again. Hope this EE WIFI HOT-SPOT on.my router gets shut v soon.
@Parasurfer49 What BT Router did you have, because the signal at that point was transmitted for YEARS just in case you missed that point, has recently been renamed as EE instead of BT as the starting prefix! It is a secure connection with no access to the Hub administration but yes it does suck the user bandwidth away if a third party connects on it!
