on 24-06-2025 04:29 PM
on 25-06-2025 08:29 PM
on 27-06-2025 09:40 AM
Hi @Jeanneypye
Has the extender stopped flashing blue since you last posted?
If this is still flashing, please get in touch with our tech guides and they can run some troubleshooting to see what is needed to get this sorted 🙂
Thanks.
on 27-06-2025 09:45 AM
@Jeanneypye wrote:
Yes my symptoms exactly. The TV from the main box works perfectly. I tried
resetting the affected TV with the wi fi code and the flashing stopped for
about half an hour then it started again. Hopefully some clever chap will
come up with the answer.
JP
Bit confused by the references to TV? What exactly is the problem? Simply the extender not pairing to the hub (and flashing blue), or is there some sort of TV box connectivity problem in the mix too?
If we're talking the extender, is the LED blue or aqua as they both indicate different things?
If you haven't already I would: -
on 27-06-2025 01:29 PM
27-06-2025 01:53 PM - edited 27-06-2025 01:54 PM
@Jeanneypye - ah, so it is a TV box you're having problems with!
Rather than use button presses on the TV Mini Box/Hub/Extender, do this on the Mini Box: -
