EE Smart Hub Flashing Green (We Cannot connect to Wifi)
Rossc441
Our Smart Hub was working fine and all of a sudden the WiFi is gone, went to check the Smart Hub and it is continuously flashing green, I have tried both disconnecting the Hub for a while then turning it back on, I have also tried the factory reset in which it turned a solid green for a few seconds, but then went back to flashing green again.
Is there anything else that may fix this issue so I cam get WIFI running smoothly again?
Thanks.
Mustrum
@Rossc441  The Help pages provides ways to get your line test and for you to contact customer services.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Text relay and sign language services
To make a text relay call using the Relay UK service, dial 18001 in front of the following number:
07953 966 150
Contact us through a sign language interpreter
Mustrum
Opening hours:
Call us
From your EE mobile
150
0330 123 1105
07953 966 150
There is no BB signal.
Which EE BB plan are you on including its speed? What EE router do you have (read its label or post a pix)?
