on 24-06-2025 04:29 PM
on 24-06-2025 06:18 PM
@Jeanneypye Seems you have pressed the WPS button, if you press it again it should dwitch off.
When the WPS button on the side of your hub is pressed, the light on your hub will flash blue. This means it's waiting for you to press or select the WPS option or button on your computer or device.
on 24-06-2025 09:03 PM
I have pressed the wps button on then mini box and it is still flashing. I can't find wps on my computer. Is there a symbol?
on 24-06-2025 10:52 PM
Light is still flashing. Can't find any other wps button except that on mini box.
on 24-06-2025 11:01 PM
@Jeanneypye is it the main router where the blue light is flashing or the extender?
Have you tried just switching it off and on again?
on 25-06-2025 02:00 AM
Try using a ethernet cable to reconnect to main router
on 25-06-2025 04:12 PM
on 25-06-2025 04:30 PM
Same problem I have been getting - works fine for a period of time then either blue flashing light or orange flashing light - no reason for it. Pairing close by works but when moved back to place orange (or blue) flashing. Done this several times and nothing works - get frustrated, lots of cursing - threaten to buy some decent branded gear and try again next day after leaving it paired overnight next to the hub and lo behold - bloody thing works again ... for a few weeks then rinse and repeat ...
on 25-06-2025 05:22 PM
on 25-06-2025 05:38 PM
@Jeanneypye have you moved the extender close to the router and then re=pair it, either by WiFi, or by connecting the two with an ethernet cable?
Leave them linked overnight or longer and then move the extender back, but maybe a little closer to the router if possible.
