EE hub as modem ?
A319
Valued Contributor
Valued Contributor
Hi, I’m looking for information to confirm, lots of conflicting details!!
Can the EE hub be used purely as a modem / bridge mode as wish to use my own ASUS router? Thanks
42 REPLIES 42
miggle
Skilled Contributor
Skilled Contributor
@A319 it's REALLY easy. in your ASUS router all you have to do is to enter the PPPoe login details in the WAN section and away you go. Literally take you less than 30 seconds. the details are in the page I linked earlier up the thread.
If you get any issues with it, just post them in the forums, happy to help.
Full Fibre Busiest Home Bundle 1.6Gb.
A319
Valued Contributor
Valued Contributor
Thanks, much appreciated .
It’s always bit daunting moving away from what you known (been VM years) and trusted.
can I still expect decent speeds do you know ?
miggle
Skilled Contributor
Skilled Contributor
well I'm on the top tier, but You can expect fantastic speeds. The BT engineer will run a test for you, and tell you your expected speed. Although because you've got an ASUS router, you can also run a speed test from that e.g.  (note edited out my SSID oops!)
Asus Router
A319
Valued Contributor
Valued Contributor
Unable to see the images you’ve posted unfortunately, just seeing a yellow triangle with black outline!?
Time has come to depart VM as CS getting worse, and a ball ache every time contract approaches end, I’m sure it will be same with EE, but at least I have all equipment in place to chop and change every contract renewal , or at least say it …
VM will have to come up with a super offer for me to stay, that’s for sure…
I  was originally a sign up with BT but I challenged them on Black Friday deals today, and been changed to EE (I know same Co) with a discount, for full fibre 900, so far, provided I can get ASUS to work with decent ish speed I’ll be happy as larry !
based on what I’ve learnt here, I plug the ASUS router directly into the wall connection that BT or EE will install - and I won’t need the EE router.
appreciate help, I will head back here on install day , 1st December for help. Thanks all.
miggle
Skilled Contributor
Skilled Contributor
you're welcome @A319 the pictures will show up once approved. You've summarised exactly what you need to do. Good luck! Let us know how it goes.
@miggle : Don't worry, your images were awaiting approval. I have now done so & they should appear soon.
A319
Valued Contributor
Valued Contributor
can now see the images, thank you so much for help and guidance with this, learnt  loads about this, didn’t know I could plug ASUS directly into wall.
will let you know how I get on during install date
A319
Valued Contributor
Valued Contributor
Hello, so today my wall connection has been fitted by OpenReach and the BB works, now I’ve removed the EE router and plugged ASUS directly into wall but nothing yet… can I ask for guidance please on the setting changes I need to make
A319
Valued Contributor
Valued Contributor
I still need help with this please
A319
Valued Contributor
Valued Contributor
I’m struggling with this… please can I have some guidance
