EE hub as modem ?
A319
Valued Contributor
Valued Contributor
Hi, I’m looking for information to confirm, lots of conflicting details!!
Can the EE hub be used purely as a modem / bridge mode as wish to use my own ASUS router? Thanks
miggle
Skilled Contributor
Skilled Contributor
@A319 I saw you ask where the PPPoE settings where in your other thread. On that very same page - the WAN setup page, at the top there is a drop-down box to select the type of internet connection. Make sure you select PPPoE from the drop-down list then just type the login information into the account settings.
Checklist:-
- Check wan connection type is PPPoE
- Enter login details
Click apply - and off you go!
Full Fibre Busiest Home Bundle 1.6Gb.
42 REPLIES 42
No! All you can do is turn off its WiFi & let the ASUS handle that.
A319
Valued Contributor
Valued Contributor
Sorry, not sure I understand that reply.
you say NO to modem mode / bridge mode but say turn off wifi , how does the equipment know to be a modem only or will this be all it can be if wifi is off ? Then by connecting ASUS it becomes router ?
By "No" I do mean No! Turning off WiFi doesn't make a modem. It just means it won't handle any WiFi connections, leaving them to the secondary router.
A319
Valued Contributor
Valued Contributor
Thank you, So if I understand you correctly, what I wish to achieve is possible, yeah ?  I can use my ASUS for the WiFi signal
miggle
Skilled Contributor
Skilled Contributor
@A319 what package are you on? if you're on fibre you can plug your Asus router into the ONT (like I do) and use that for wifi/internet.
There are instructions on this forum for using a third party router here:-using-and-configuring-a-third-party-router
If you wish to retain your existing hub, (or you're not on a fibre connection) - you can turn off wifi on it, and just use your asus  as a secondary router as mentioned above. 🙂
A319
Valued Contributor
Valued Contributor
Sorry, what do you mean by plug into ONT ?
currently on VM 600mb using hub3 and its used as modem with ASUS acting as my router .
but considering changing to EE / BT full fibre 900 but need to be sure I can continue with same
bobpullen
Like @miggle says, if you're moving to full fibre then you'll be able to connect the Asus unit directly to the fibre termination point via it's WAN port (with some minor configuration). You won't need the EE-provided hub at all if you choose not to use it.
miggle
Skilled Contributor
Skilled Contributor
@A319 you will be provided with an ONT that is mounted on the wall as part of your installation. You can plug the ASUS router directly into the ethernet socket on that as @bobpullen says.
That goes into your WAN port on the Asus router.
For reference it looks like one of these:-
ONTONT
A319
Valued Contributor
Valued Contributor
Ah right, the terminal provided at installation I plug straight into that… get it. Thanks.
is the configuration required easy for a novice?
appreciated
