EE fttp pings and latency question
kannann
Hi there,
Are the pings and latency low if connected by ethernet? I’m coming from Virgin and would like to compare before I actually make the jump.
When i used to be on fttc years ago with BT was getting pings close to 5ms to bbc and google etc.
Is it going to be the same with fttp?
Maestro
Maestro
@kannann You get no assurance from any ISP with ping/latency, link to post if you wish to see and read recent posting. With VM what are you like at present with your ping? Network connected you are certain to be lower, fttp will let you know install is Tuesday if it does not get stuffed again, but more hopeful as now GAURANTEED OR are doing this time and not the contractor.
Huge ping/latency spikes after switching to ee - The EE Community
And any other potential features you may need, look on the forum also before you decide!
Slightly faster. Shouldn't be noticeable.
