EE broadband app WiFi controls spinning
Huggons1
EE broadband app WiFi controls spinning, when attempting to setup in app
EE executive complaints team say that this is a known issue and affected customers (around 1000 affected customers app version 5.75.0) will have to wait for an app fix to resolve the issue.
Still not resolved in update 15/12/2025 app version 5.76.0. 5.76.0.was released today for both iOS and Android.
Same issue on IOS and Android. Just spinning, when attempting to setup wi-fi controls. Issue ongoing for months. Broadband support helpline not even aware of the issue and took a complaint to acknowledge the fault.
Hope this helps someone.
34 REPLIES 34
Having the same issues. Another post is circulating as well from earlier this week. CS advised me to raise a complaint which would be closed as there is no time frame for a fix. It’s annoying as I can’t control the home settings needed! At least the broadband itself works!
Bob9395
Christmas Eve and I have the same problem trying to connect my new WiFi 7 router to the app … spinning circle .. I rang the help desk who told me it’s a known issue and will be resolved in due course
My point. Wait how long. I asked what are they doing for compensating customers and they said nothing currently.
my part fibre connection is not worth the hassle I’m moving
Huggons1
You need to have the first level support team raise a fault to TMC Operations
Technical Management Centre team, to have the issue resolved.
Hope this helps.
This has been done. I have a callback today from executive complaints so we will see what’s going to be done. Thanks for your advice.
Huggons1
No worries, a word of warning though. I had a complaint logged with the Exec team and they were barking up the wrong tree and said that I would have to wait for a fix. I reached out to TMC, who could see what was causing the issue and corrected the data on my account, which was causing the  spinning issue. Had I left this to the Exec team, it would never have been resolved!
Daymoalexander
Valued Contributor
Valued Contributor
I believe the executive team are regarding not being able to change my broadband package I’ve somehow upgraded to the full ultimate package on part fibre. Stuff I don’t need for that price!
I did escalate this as a first point of call to an advisor who said it will be logged with the team who do the app etc and that there is no time frame for a fix. It’s bad enough to make me go back to sky!
Huggons1
Hope you get it sorted soon. If all else fails, I can give you an email address to reach out to the team.
Kind regards
That would be helpful tbh. As I haven’t been given a time to fix. This was working then it just stopped as my router was reset by the cube engineer. Now, as I tell them, I don’t have any access to controls.
Could you lets me know the email address too please .. I rang today but not sure they logged it as I was told that they are “working on it” .. thanks, Bob
