EE Wifi
anthony135
I cannot OPT IN to wifi
I have EE made for gamers, it went live today so it is a new connection
how do i get it so i am opted in.
thank you
12 REPLIES 12
Christopher_G
Hi @anthony135
Welcome to the community.
If your 'go live' day is today, it may be that your account is still being fully set up. Could you give it a try tomorrow and let us know if it works?
Matt_124
I am unable to see your image as it needs to be approved by a moderator, but are you sure that you're signing into the right WiFi SSID? Your use of the terms "Opt In" makes me think it could be the wrong WiFi connection.
Your router will appear as EE-****** (where the * is a sequence of letters and numbers that should be visible on the card that detaches from the back of your Hub).
If it is "EE WiFi" you're trying to sign into, this is a public hotspot and not the actual details for your Hub.
Don't worry, the images were awaiting approval. I have now done so & they should appear soon.
The OP is trying to use the public EE WiFI network, not his own router, & should be logging in to it with his EE ID a/c creds.
I am trying this. but i get an error "Please check you are registered to access Wifi."
and then i get the other error when i try opt in
Then the advice of @Christopher_G to wait is probably best to let your EE a/c be set up.
Matt_124
Makes more sense now cheers @XRaySpeX.
@anthony135 Sounds like it may be because it's the "Go Live" day today as @Christopher_G  says and that the EE WiFi system doesn't recognise that you've gone live yet as an active EE Broadband customer.
It's possible that there's an issue with registering for EE WiFi when you're on the 1.6Gb packages as the EE WIFI asset tag might not get automatically applied to those accounts unlike the other packages due to the new tech ordering system. But it's hard to say at this early stage, it's more likely to be the former and if you give it some time it may begin to work.
anthony135
thank you all for your replies. i will wait a week and is not resolved i will reach back out.
anthony135
I know i said i would wait a week, but i got woke up and thought i would try on the off chance. there is a hotspot near where i live.
it is still the same
Alex_H
@anthony135 Try using another browser to complete the EE Wi-Fi opt in, or after clearing the cookies and cache for the EE website from your current browser.
If the issue continues it will be best to report this to our broadband technical team so they can help get the issue resolved, allowing you to opt in and then make use of the EE Wi-Fi hotspots. Contact Us To Request Technical Support for Broadband and Landline | EE
Alex
