EE WiFi Extender 7 Pro as wireless access point
Mansoor16
How do I set up the WiFi extender 7 pro as a wireless access point with ethernet connection. Is this possible.
I currently get 300mb in 1 room with the wireless setup but want to know of i can connect ethernet from the hub to the extender 7 pro to make mesh network and get full speed on the extender 7 pro if connected with ethernet
Community Hero
Community Hero
@Mansoor16 Yes, Ethernet cable from the EE Pro hub to the EE Smart wireless, gives you wired backhaul at the smart wireless and full speed that your device can do as a wireless wifi connection!
Community Hero
Community Hero
