EE Smart WIFI Plus SW30A - PoE?
Raphael1
Does the EE Smart WIFI Plus unit support Power over Ethernet (PoE)? So that the unit does not need to be plugged into a power socket?
bobpullen
Star Contributor
Star Contributor
bobpullen
Star Contributor
Star Contributor
No, they don't.
Raphael1
OK - thanks for the quick reply 👍
