27-06-2023 04:29 PM - edited 27-06-2023 04:30 PM
When I look at the wireless I have quite a number of unknown devices showing green, so connected and therefore I cannot remove them. Is there any way of removing them as I have no idea whether they are genuine connections or not, and I don't really want to have to change the password as I will have lots of known devices to reconnect.
I have also noticed that my Pixel 6 phone is showing there as four connections, but I have had it powered off for the last hour to test.
05-08-2023 08:53 PM
@Loopylass @Wavydavy If you have the the white router you can not remove them. Only a factory reset will remove them.
05-08-2023 09:04 PM
Then, @Chris_B , why is there a "Remove" button against them all?
06-08-2023 08:15 AM - edited 06-08-2023 08:16 AM
@XRaySpeX There isn’t on my router. That’s the white smart router. Unless there’s been an update that I’ve not received yet.
06-08-2023 11:10 AM
@Chris_B : Ah, there was in FYI: EE's New Smart WiFi Router UI Admin Interface . Thanks for info.
@Loopylass , @Wavydavy : That settles it!
06-08-2023 11:19 AM
Mines is a black router
06-08-2023 11:22 AM
@Loopylass : That's a Smart Hub. You can Remove devices on that.
22-08-2023 07:11 PM
Hi please can you help. I don't seem to have the remove button when I open up each device or look at my device list. Also tried a factory reset from the router and nothing changes and all devices stay attached. Can you advise
22-08-2023 07:14 PM
@Laudux : Which router do you have? As found above, you can on the black Smart Hub but not on the white Smart Router.
22-08-2023 07:24 PM
A black one but can't see the button to remove the device
22-08-2023 07:29 PM
I've logged in initially on my phone and there's no remove button but it's appeared when I logged on using a different device to the route. Thanks for your support
