EE Smart Hub Pro cant change 6Ghz channel
B00b1esRfun
I have the 1.6Gbps service and have found the WiFi extremely disappointing coming from my Asus ROG GS-AX3000. From what I can see you cannot change the 6Ghz channel from 69.
My 2023 Macbook Pro says that the 6Ghz channel is using a different SSID, of which it isn't as you can't split the channels on this piece of junk even if you wanted to.
Also, why would EE supply a router with an ethernet cable that only supports a max of 1Gbps?!!
The app is all but useless and the web based one is no better!
I stupidly activated Game Enhance which has now swtiched my 6Ghz channel and despite turning it off the rescan for Channel 6 is greyed out.
Any ideas please?
11 REPLIES 11
@GosforthUK : That public IP is from a BT pool.
GosforthUK
Skilled Contributor
Skilled Contributor
@XRaySpeX yeah, I know (AS2856) but never seen it, apart on start of my 1.6 Gbps BB and now, after reset of ONT...
Everytime other it was 17x. and 16x. range...
