EE Smart Hub Plus and Sky Q Connection Issues
mdnn85
We recently switched our Broadband from Sky to EE's Full Fiber 500, however, we remain with Sky for their TV services and have a Sky Q box (not sure if it makes a difference but the box is for 4K TV with 1TB SSD).
Since switching we updated the settings on Sky Q to connect via the WiFi, however, on a daily basis we have to go through the process of either re-entering the password or resetting the Sky Q box as it keeps losing the connection. This issue only occurs with the Sky Q box, all of our other devices such consoles, phones, tablets, smart devices etc stay connected without any issue.
I have contacted Sky and have gone through some trouble shooting steps with them but nothing so far has fixed the issue and they suggested it may be something within the settings of the router. Unfortunately the location of the EE Hub means we're unable to connect the Sky Q box via ethernet.
I have seen posts on several forums where people have had this sort of issue with EE equipment and Sky Q but the only resolutions I have been able to find must be for different routers as the settings mentioned don't appear to be in my settings page.
If anyone could help with this I would be really grateful 😊
16 REPLIES 16
kinoultonkid
Btw @XRaySpeX  do you know, what is the root cause of this connection issue?
Probably a clash between your device & WiFi6 &/or WPA3.
stuartw57
Had the same prob...ee sent out engineer to sort connecting prob like yourselves..OK foe a bit now starting again..Will be on phone again tmw..good luck..
TheMews8
We have the same problem SKYQ box loses the connection to EE router every 2 or 3 days. I have seen a couple of suggestions about changing the router settings to switch off 5G and avoid certain channels. Has anyone tried switching off 5G with any success? I am reluctant to do it incase it messes up all our other device connections.
@TheMews8 You do not want to be switching off any wireless wi-fi bands on the EE router. SKY Q can connect on 2.4 or 5Ghz so have a look at Sky Q settings, if you have a Plus/Pro router then you may also wish to look at using the compatible wi-fi feature.
TheMews8
Ok that’s helpful thanks. I will try the compatible  Wi-Fi.
@TheMews8 You can also have a read at this post from back in Jan to see if it is off any use.
Solved: Sky Q and EE app issues - The EE Community
