EE Compatibility with House Alarm
999Para
I am considering subscribing to EE broadband. However, there is some confusion surrounding if the EE broadband is compatible with House alarm systems such as ADT. Obviously if EE broadband is not compatible with my ADT house alarm then I won’t be able to take out a subscription with EE. Can anyone clarify this issue?
Community Hero
Community Hero
@999Para Will be the same for any ISP that you go to if the ADT has not been modified to suit! Nothing to do with EE!
Mustrum
@999Para   which Alarm system do you have now and how is it connected to your current broadband supplier?
Some systems have an ethernet LAN connection, others via WiFi.
Who is your current broadband provider?
