EE Broadband Large Ping Drops and download speed halfed
fabricate
Broadband has suddenly gone really poor, download speed has halfed, we dont even get the quoted downloaded speed to begin with. and the ping is awful spiking up to 150ms+
Is ther a fix or any idea what is going on?
What was your quoted d/load speed?
