01-04-2025 01:51 PM
I saw a number of previous posts at the end of last year that people were having issues with the EE App after being moved over from BT.
We only moved over in Feb/March and are having the same issues. I want to try and run the tests because our wifi connected house alarm keeps dropping connection and waking everyone up each night so trying to work out the issue (only started since the new EE WIFI).
Spoke to EE Customer service and they said they were not aware of the problem so wanted to see if others were still having an issue.
30-07-2025 09:52 AM
@sea2dog : There isn't an EE "superhub"! What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
30-07-2025 10:04 AM
I have the smart hub plus
30-07-2025 10:06 AM - edited 30-07-2025 10:08 AM
@sea2dog Take a look at the various EE Routers link below, and the pictures give them away, EE Smarthub (2023) is the same and direct replacement for the BT Smarthub2 version, if you have the Plus or Pro then you are into more serious equipment spec, any Router change can be difficult so that is not to be unexpected in the least but they do try to make it easier but does not always work out that way!
Edit:- Not required as mid posting between response...
30-07-2025 10:17 AM
I checked your link and can see mine, it says on this on via your link that it's WiFi 6, yet when I go to my WiFi settings it says WiFi 5, why would this be?
30-07-2025 10:23 AM
30-07-2025 10:26 AM
It would appear it depends on the phone device whether it displays as WiFi 5 or WiFi 6.
30-07-2025 10:30 AM - edited 30-07-2025 10:32 AM
Btw, I can actually do a speed test on my ee app, my issue really was it not always changing from 2.4ghz to 5ghz, it did this morning so maybe the rebooting and cache deletion helped.
One part of the app would tell me it couldn't restart my hub,, but it physically did, so probably an app bug.
30-07-2025 12:28 PM
@sea2dog And there will be many off those in your expected operation with the app and the router! Best off luck with it all and hope it all settles down for you now!👍
30-07-2025 12:32 PM
Thank you. 🤗
