Not everything is terrible
jak26
Naturally most posts are about problems - but not a huge number given the number of customers, but with full fibre and only 2.4 GHz compatible from the hub 7+ with most things wired or 5/6 GHz via an Asus AP I can't find that much to moan about after a couple of months - no speed dips or WiFi dropouts etc.
Recently I've seen an improvement on the cloudflare speed test that seems a slightly more pessimistic measure of speed & latency as well as a measure of jitter. Maybe something's changed in the network - no hub f/w update yet - as it's now giving three "greats" - the best I've seen before were good or average - let's hope things stay like this.
Maestro
Maestro
@jak26 High percentage would be about wifi, compatibility of devices with wifi security, and in your case the way you have it all setup you really should be great as long as your Fibre feed stay's up and good.
Never once found the Fibre from ONT onwards with any issues, EE Gear was always the problem especially after FW updates.
If you really want to thrash and see how good it is, then see the linked below.
Re: 1.6Gb keeps fluctuating between 0 and 1500Mbps - The EE Community
