01-02-2026 02:01 PM
For some reason my EE broadband download speed is only 16mbps and is supposed to be at least 48. Not sure how long it has been like this as we have been able to do normal browsing etc but it still bothers me that I am not getting what I am paying for. I am wondering if I have a damaged phone line but the original source of it is under a storage heater…. It was moved to a different socket 40 years ago and has been fine BUT my question is, if I had an engineer out could they sort out a potential wire problem without needing the heater removed? I can’t think what else it could be.
01-02-2026 02:08 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
