Download speed has dropped!
JoRDT80
Just yesterday I had my broadband installed, after waiting 2 weeks with no internet, because one of your engineers decided to only do half the job. My wireless speed to my PC was going up and down, started at around 15mbps, then up to 60 mbps, now its as little as 1-2mbps and isnt increasing atall. This is unacceptable, I can barely watch a video. We should be getting up to 900mbps ive tried restarting router etc. It cant be my wireless adapter because i havent moved it and was getting 60+ just yesterday morning.
6 REPLIES 6
JoRDT80
Serial number:+EEH002+2235001263
Firmware version:v0.05.00.03231-EE
Firmware updated:unknown
Board version:R01
GUI version:1.1 28_11_2019
DSL uptime:0 days,00 Hours13 Mins09 Secs
Data rate:1000 Mbps / 1000 Mbps
Upstream error control:Off
Downstream error control:Off
Data sent / received:158.5 MB Uploaded  / 10.9 GB Downloaded
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:AC:B6:87:86:48:00
Software variant:-
Boot loader:0.1.7-EE (Fri Sep 20 18:43:31 2019)
JoRDT80
I hope that is what you mean
JoRDT80
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
8072.2201966.7AvailableAvailable
8069.8201962.6AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessWBC FTTP
Up to 1000Up to 220--Available1 Stage
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 7.5--5.5 to 12Available
Up to 7.5Up to 15.5 to 12Available
Up to 5.5--4 to 8Available
2----Available
2----Available
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in JumperWBC SOADSL 2+SOADSL MaxSOADSL Fixed Rate
Up to 7.5--5.5 to 12----
Up to 5.5--5.5 to 12----
Up to 2--4 to 8----
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
JoRDT80
JoRDT80
can you help atall?
