Does the EE Broadband Router do PoE on its LAN ports?
gigcoyle
I want to install an outdoor WAP but does the EE router do PoE on its ports?
@gigcoyle  No. But you can get a POE switch.
Weebles2025
Valued Contributor
Valued Contributor
@Chris_B @gigcoyle
That's overkill for just installing a single WAP, much better to spend about £5 on a PoE injector than £60+ for a PoE switch.
@Weebles2025   That’s was straight from the top of my head.  And where are you getting POE switches from at £60+ ?  You can get them from £25 for a five port
Weebles2025
Valued Contributor
Valued Contributor
Those cheep £25 ones are only good for powering low powered CCTV cameras and not WAPs. Better to get an injector that way you are providing the correct power for the WAP.
