Device connection being made, however internet connection is not
Eddy888
Devices are connecting to the smart HUB 6  plus however the connection being made doesn’t allow the device to connect to the internet. I have tried all the connection Issue troubleshooting methods. Once I start the power cycle  The lights shown seem to be in the correct order, so once the WiFi address is available, connection can be made, however once I have entered this area I can’t go further. Meaning no internet access at all. I’ve tried using an Ethernet cable to access the WiFi, but same issues arise. the address is discoverable but the connection to the internet isn’t made.
@Eddy888  Have you checked the cable from the wall box to the router ?   What colour led is on the router?
Maestro
Maestro
bobpullen
Star Contributor
Star Contributor
@Eddy888 - is there a possibility you've inadvertently configured some parental controls settings/schedules at some point that's blocking Internet access? Can affected devices get to the Hub manager at http://192.168.1.254?
