27-03-2022 01:42 PM
Dear EE CS team,
I have the latest smart hub. It has been working well and stably for a while, about 1 month. Then the internet connect starts flucturating. It drops out and reconnects often. As long as it is connected, speed is very fast. I have tried to reset the router by pressing and holding the reset button at the back of the router. After the fist time I did that , the internet had been stable for about 20 days. The issue is back again. I tried to reset the router using the same way the day before. It isn't helpful this time. I am suspecting there could be something wrong with EE server(s).
Look forward to hearing from you. Thank you.
Kind regards,
Liam
27-03-2022 02:32 PM - edited 27-03-2022 02:34 PM
Welcome to EE's Home Broadband Forum. This is not the EE CS team!
