23-02-2024 03:52 PM
Please can someone help. I've just been changed over from BT landline and broadband to EE landline and Broadband, or at least I should have been. Apparently the system is ready, So they have cut off my previous landline. Howver I have not received the hub just a home adapter. Is it possible to get the phones up and running with this but without the hub? When I look at the order the only item listed is the adapter. Is there a telephone number to ring to find out what is going on? Any help would be appreciated. A landline is important as mobile signals here are very poor especially EE!
23-02-2024 03:55 PM
Is it possible they expect you to continue using your BT router?
23-02-2024 04:00 PM
23-02-2024 04:09 PM
Try calling CS on the Freephone no. in my sig.
28-07-2024 10:03 AM
I have not received my EE hub
31-10-2024 11:13 AM
Have just poster same question. Total chaos.
31-10-2024 03:45 PM
Hi @Buster999,
Welcome to the EE Community
Has your broadband went live today? Did you still have your router you were using with BT and does that work when plugged in?
If you have not already please reach out to our broadband team by calling 150 from an EE mobile or 0330 123 1105 from any phone so our team can take a look into your order and the hub not arriving.
Alex
31-10-2024 04:14 PM
Hi had same problem. used phone number given in post below. Chap told me to take phone cable out of box at entry to dwelling and plug in to my BT router in the green slot on the back of router. It worked it might be the same for you.. Good luck.
31-10-2024 04:28 PM
