Can I continue to use my BT router after being forced to EE
Notts1947
Mustrum
@Notts1947  you should be able to, unless you have also moved to Digital Voice and your old BT router does not support this - or if you have been asked to return it.
Also your BT router will only support WiFi-5. The EE Smart Hub Plus, if they give it to you, is WiFi-6.
