Broadland problems
Nikki96
hi is there anyone else having technically problems with the broadlands internet? This been going on over 1 month now seems be down on and of quite alot
Mustrum
@Nikki96  what issues are you haveing, and have you reported the problem to the Broadband Care Team?
The following Help Page may help you get started with some troubleshooting.
https://ee.co.uk/help/broadband/manage-use/manage-your-ee-hub
Or the Contacts us page
https://ee.co.uk/contact-ee/technical-support/broadband-landline
BB faults are rarely area-wide but specific to your particular line.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
