Broadband
CosminaCodreanu
Hi! How can I change the password on my wi-fi? Thanks
Yes, it was. Login to your EE SH/SR at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router. Then on the Advanced > Advanced WiFi page you should be able to see your WiFi password in clear & change it if you like.
Northerner
Hi @CosminaCodreanu
Under the router settings you can change the password.
Which router do you have.
CosminaCodreanu
Smart hub plus? I’m not sure if this is what you asked me…
