on 14-07-2023 09:57 AM
on 14-07-2023 10:19 AM
Hi @Felipe80,
If you log into your My EE account and select 'Broadband' then there is a section where you can download your bills. Your account number will be on the top of your bills.
Thanks,
Alex
Hi @Felipe80,
Thanks,
Alex
on 14-07-2023 02:37 PM
@Felipe80 : Have you registered your BB to MyEE? If not, you will need to do so before you can see your bills.
Your BB a/c no. should be found in your Welcome email. If you no longer have it you will need to contact CS to find it out.
