on 23-05-2023 10:52 PM
Is anyone else having issues with EE broadband? For over a week mine is constantly disconnected. And when I attempt to check it through the EE website, the page can never be found. Starting to wonder what I pay for!
on 23-05-2023 11:47 PM
What Device your used. is that 5G Device?
on 24-05-2023 12:41 AM
BB faults are usually specific to your particular line.
