Broadband speed
Poor3
What are acceptable speeds   ?
I am getting download 0.07mb/s  and upload of 0.29mb/s   EE tell me this is best I can expect
6 REPLIES 6
Mustrum
@Poor3  they do sound very poor speeds.
Availablr speeds depend on a number of things, how far you are from the exchange for ADSL, how far from the cabinet for VDSL/FTTC or if you can get fibre then you should get the speeds you sign up for. These speeds are the sync speeds, not what you test, these can vary with use on your line.
The first thing to look at would be entering your details - ideally phone number, if not your address into the BTW DSL checker which will show what services you can get at your property via Openreach lines. Post the results, include the complete table with the text below, but hide your phone/address.
https://www.broadbandchecker.btwholesale.com/#/ADSL
To answer that would need a lot more info about your line & its performance, as below.
Mustrum
@Poor3   That shows you are a very long way from the exchange and only very poor speeds available at present.
Have you explored any other suppliers or technology?
I am guessing mobile signal is also poor?
Any local community initiatives?
Or satellite services ?
Good Morning, EE did a reset yesterday so I am blessed with a speed improovement todaytest3.JPGtest4.JPG
Well, unless you post the requested router stats we'll never find out why it's so slow & whether it can be made faster.
