Broadband speed.
Bullrush
Bullrush
With toob I can get 900 Mbps compared to EEs 27 Mbps and 19Mbps.  My contract ends soon so I will be leaving EE. Are there any special deals on to keep me as a customer
@Bullrush : What about it? Please explain your issue & circumstances in greater detail so we may be able to help you with it.
@Bullrush : Welcome to EE's Home Broadband Forum.
Mustrum
@Bullrush   by toob, I presume you mean you have access to City Fibre who seem to be laying full fibre in many towns and cities at the moment. Unless Openreach have plans to do the same in your area your speeds will be the same as they are now if you stay with EE.
As for deals, you will need to give the Broadband Care Team a call to see if they can tempt you to stay.
