Broadband not working well
Wilfy2102
Please can you check my Broadband is working properly. Signal keeps dropping out
Christopher_G
Hi @Wilfy2102
Welcome to the community.
Is it fixed line broadband or Mobile Broadband? If it's fixed line, are there any changes to the lights on the front?
