Broadband issues
AristidesMerino
My broadband has been unstable since 3 days ago, It's been disconnecting every 5 mins.
7 REPLIES 7
Maestro
Maestro
@AristidesMerino As you have not supplied much info regarding what is going on or what service that you have but if you are on the new EE, use the link below and the text service, if on older call them and have your line checked.
Contact Us To Request Technical Support for Broadband and Landline | EE
Which EE BB plan are you on including its speed? What EE router do you have (read its label or post a pix)?
My router is a smart hub plus and the service a 41 mb
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
I mostly use my internet by ethernet, so the problem isn’t that. Wifi doesn’t work as well and the light of the router is yellow by now. Before it was yellow all the time the internet was dropping every two minutes, and now as I said, it’s yellow and no internet at all. I’ve attached a pic of when I log into the router.IMG_0025.jpeg
Yeah, but that's not I asked for. It tells me nowt other than than you have a Smart Hub Plus,
@AristidesMerino What the lights mean link below, yellow is not one of them. Possible it is orange though. Would text HELP to 66033 and have EE check your line just incase it's developed a fault on it.
https://ee.co.uk/help/broadband/fix-problem/what-the-lights-on-your-ee-smart-hub-mean
