Text HELP to 60071 (charge may apply at your standard rate)
16-02-2023 09:10 AM - edited 16-02-2023 09:14 AM
Hey all.
Im recieving poor service at the moment, i have a sogea connection. I dont expect 100% like i may have in the past when i hosted my own services (Minecraft servers and peer to peer gaming) but i dont really expect multiple disconnect a day. On Monday 13th i had 9 drops.
How do i raise a ticket to get someone to have a look. I know there is a phone number, but i dont have time to sit on the phone currently.
~I should add i run my own equipment, a Vigor v166 and pFsense firewall, but this happened with the standard router/modem. Its in our bedroom and it would wake me up in the night with a click when it drops and the flashing connecting led.
on 16-02-2023 11:05 AM
on 16-02-2023 11:36 AM
Its deffo not the wifi, I run Uniquity AP's,the issue is internet access.
| Feb 16 04:01:54 | ppp | 11367 | [wan_link0] Link: UP event |
| Feb 16 04:01:54 | ppp | 11367 | [wan_link0] PPPoE: connection successful |
| Feb 16 04:01:54 | ppp | 11367 | PPPoE: rec'd ACNAME "acc-aln1.gjc" |
| Feb 16 04:01:48 | ppp | 11367 | [wan_link0] PPPoE: Connecting to '' |
| Feb 16 04:01:48 | ppp | 11367 | [wan_link0] Link: reconnection attempt 7 |
| Feb 16 04:01:44 | ppp | 11367 | [wan_link0] Link: reconnection attempt 7 in 4 seconds |
| Feb 16 04:01:44 | ppp | 11367 | [wan_link0] LCP: Down event |
| Feb 16 04:01:44 | ppp | 11367 | [wan_link0] Link: DOWN event |
on 16-02-2023 12:39 PM
@TheDarkLord Why not get a call back?
https://ee.co.uk/contact-ee/technical-support/broadband-landline
Monday to Friday 8am - 9pm
Saturday and Sunday 8am - 8pm
on 25-02-2023 12:54 PM
60071 doesn’t seem to be working recently. I’ve tried various versions of help, in upper and lowercase, and with our landline number included, but just get not sent in reply. All other texts seem to be working fine. This was a great tool and saved having to fight with the call centre queue.
on 26-02-2023 01:44 PM
Hi @MikeyBoy28,
Are you still experiencing the same issue with the text service?
What type of phone are you using?
on 27-02-2023 09:34 AM
Yes James.
just tried it again on my relatively new Oppo Find X5 which uses Google Messages. Just get “Not sent, tap to try again” and that’s the same response every time I send a message.
on 27-02-2023 09:36 AM
I'm sorry to hear this @MikeyBoy28
Please call us on 0800 079 8586 and the team will get this looked into for you.
Leanne 🙂
on 27-02-2023 09:47 AM
@MikeyBoy28 Does your phone not have an option to send a txt/sms rather than google message?
on 27-02-2023 10:56 AM
Dunno Mustrum. I thought that’s what it was doing, but couldn’t find any settings to control things. I’ll have another look.
