on 28-02-2025 06:33 PM
Good Afternoon Everyone,
I have been with EE Broadband for several years and have pretty been faced with zero issues in terms of speed and connectivity. We have always averaged 70mbps down, 20mbps up and around a ping of 25. In terms of activity on the network, on a typical day the router will have around 6-7 devices connected to it including a desktop PC that is connected via ethernet. The desktop and WIFI will both see the speeds mentioned above but since last week, whenever a game is opened on the desktop or a video begins playing, the ping shoots up to over 300 and the download speed drops down to around 15mbps. This is also showing the same for the WIFI connection when it is happening. Give it 10 minutes and it'll recovery itself fully. I have phoned EE regarding it and in fairness they had a new router sent out to us ASAP but unfortunately that didn't seem to fix out issue. Further to this, they are now sending out an engineer at the beginning of March to investigate further.
However, I thought in the mean time, I would seek some advice regarding anything I could possibly do in the mean time to troubleshoot some issues? If any one has some advice or has seen this issue before, I would greatly appreciate some insight to a fix.
Many Thanks!!
on 01-03-2025 10:15 AM
Good morning @rhys1573, welcome to the EE Community!
I'm glad to hear you've managed to get in touch with our team and an engineer is going to be on the case!
What steps have you tried in getting this resolved so far, and is it only the desktop you're noticing these issues with when gaming and watching videos, or do other devices experience similar problems?
Peter
on 01-03-2025 10:28 AM
Hi Peter,
This seems to be occurring on all devices as when I completed a speed test during the same time the desktop PC was having the issue, I noticed the WIFI devices were also being effected. So as far as I am aware, its not only the desktop with ethernet that is having the issue, it is also the WIFI devices on the network.
In terms of troubleshooting, I have tried the generic router reset, and checking the connections to the router and PC. After some digging around online I seen a suggestion to ensure that the 5Ghz WIFI was enabled on the Hub Manager. I found it already enabled and haven't been able to find any other suggestions online.
Rhys
on 01-03-2025 01:58 PM
Thanks @rhys1573, another step you could try here is disconnect all the devices currently on the network, and test and introduce them one at a time.
That way we can say for sure if it's interference from a particular device causing these issues, or something with the way the Hub itself is configured.
Peter
