on 08-10-2025 08:31 AM
Broadband has been down since morning of 7th October have had 3 messages from EE, one saying they were dealing with the problem 2nd apologising for it taking so long to fix and a 3rd this morning the 8th October at 07.30 saying it was fixed and to restart the system
Have rebooted router several times and still no internet connection, the flashing orange light does work though
Solved! Go to Solution.
on 08-10-2025 08:58 AM
@DW197018 Once it is fixed then the Orange will stop flashing for you!
on 08-10-2025 10:36 AM
Thanks Jim
my comment on Orange Flashing light still working was sarcasm as apparently the issue is fixed
