Boardband
Pearsonclaire89
My boardband keeps going on and off all the time I've only had for about a month and it crap
Christopher_G
Hi @Pearsonclaire89
Welcome to the community.
How often would you say it goes off? Does it come back on itself, or do you have to reset the router?
