09-08-2026 05:28 PM
Hello a month ago I renewed my boardband from 35 essentials to 50kor and it’s so much worse why is that
09-08-2026 05:38 PM
Are they both on FTTC, i.e. Fibre 35 Essentials & Fibre 50 core?
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
