Back up hub
lizchris15
Our back up hub has red flashing lights at the bottom.. what does this mean and what do we do
What hub is it? What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
Thanks !
Sent from Yahoo Mail for iPhone
@lizchris15 Are you talking about an EE Hybrid unit if that is your reference to a backup hub? If so the details are linked below for you!
https://ee.co.uk/help/broadband/getting-started/hybrid-connect-set-up
https://ee.co.uk/help/broadband/fix-problem/fix-smart-hybrid-connect-broadband-problems
Thankyou so much
