BT wifi disc extender on full fibre EE router
MUSH247
I have a BT WiFi disc extender , is it compatible with full fibre EE router? If yes, how can I connect it to the router?
Mustrum
@MUSH247   you don't say which extender or which router, but the answer is normally no. The EE routers have specific extenders designed to be used with specific router.
If you used to do any control via the BT App for your extender, you won't be able to do so on the EE App.
The black BT Complete WiFi discs don't work with the current EE Smart Hub Plus/Pro routers. It's only the white "High St." Whole Home discs that do.
