2 internt providers?
Endjinn
My house mates use up all the routers ports and I'm wanting to get my own Internet provider. They use BT.
Could EE provide me with separate Internet?
@Endjinn   Why not just get a Ethernet switch.  You just plug this into to the router and then you’ll have more ports to use.
You just remove an Ethernet cable from the router plug the switch in to that port then plug that cable back in to the switch and you’ll have more ports to use.
@Endjinn : Should be able to. Check out Broadband Deals
Can't you use WiFi to the router & save on ports?
