2.4ghz smart plugs and EE Smart router
Bonz_79
I've literally just set up my new EE Smart router. Everything is working fine but when I go to connect my smart plugs/doorbell it just won't connect as they use the 2.4ghz band. Is there anyway I can split them or something? Some help would be appreciated
12 REPLIES 12
@Bobinfowey   which router do you have?
Newer EE routers have a different option these days.
@Bonz_79 You may wish to also say which model off camera doorbell, and try not to go on a post so old, @Mustrum has asked you the relevant question to get started. More precise the info is, then less guessing needs to be done.
@Bobinfowey : Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router. Then on the Advanced > Advanced Wireless page you should be able to change the WiFi settings as I recommend while you connect the doorbell.
