on 08-06-2026 06:56 AM
Hey
We're having issues with our 2.4ghz continually dropping, so none of our Lamps, camera or Alexa work, nothing's changed or been added etc, spoke to Customer service 5 days ago who did a reset and raised a complaint, it all worked after that and now it's stopped again for no apparent reason, any ideas? Do we need a new hub?
We have Fibre to the door so it's normally super good and consistent and was all working brilliantly when we had BT BB but the EE BB has been less reliable
08-06-2026 08:24 AM - edited 08-06-2026 08:34 AM
@EmC154 What hub are you using, see links below. Only for the EE Smart Hub 6 + and the 7 Pro versions that have been FW updated starting around the 25th May onwards...
And if you fall into this? See the @bobpullen Answered method for the quick fix!
Solved: Re: my outside camera keeps going offline. - The EE Community
on 08-06-2026 08:50 AM
Thanks we have the 6 + will try the channel change and if not will come back
on 08-06-2026 09:16 AM
We've don't that previously but still working for a bit and then dropping off
08-06-2026 09:31 AM - edited 08-06-2026 09:33 AM
@EmC154 Are you using the Main and the Compatible networks on the 2.4Ghz band, when did you change the Hub from the BT one to the EE one? Would also power off the Hub for five minutes after you have applied and saved the changes so that they take effect....
on 08-06-2026 07:16 PM
Hi, just retrying and changing the password on the compatible network, so will see how that goes
I think it's been about a 6/7months since we went from BT to EE, and it wasn't a great experience, it was previously consistently reliable and since it's been dropping regularly both the 5gh, and now this with the 2.4, it's really frustrating
08-06-2026 07:21 PM - edited 08-06-2026 07:27 PM
@EmC154 Be careful then, the FW update that has been applied may not be the whole cause off your current issue's and you could be having a Hub issue.....
It's only been since the FW update that relates to SOME user's with issues so not sure if it is at all widespread. Below is how the FW updates have kind off went so worth a look see what you have.
Do you have any external booster's / range extenders / AP's etc to the EE Hub?
Do not have any EE Equipment, but do see if the Comp can be set fixed channel also, if so have the Main and the Comp on the same first, if not stable select opposites. ie one on channel 1 and the other on 6 or 11.
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3. 17/09/2025 Now https://
FW: r3.8.25-R-1595997-PROD-1 and the gui is at App version ?.?.?. 23/12/2025
FW: r3.8.26-R-1595999-PROD-1 and the gui is at App Version is 3.1.3.19 24/12/2025
FW: r4.28.1-R-1882725-PROD-1 and the gui is at App Version is 3.14.5 31/05/2026
on 13-06-2026 07:22 AM
It's continuing to drop, called CS again and they think it's the FW which is the cause, but waiting to hear back post engineer review, but not sure what's gonna happen to resolve
We do have one extender as the WiFi doesn't reach our extension
13-06-2026 07:56 AM - edited 13-06-2026 08:12 AM
@EmC154 Not sure were you are at, the fault has been found and EE are now rolling out the new FW update to the hubs Below is for the EE Smart Hub 6+ version only, little bit unsure what is correct until OP post's back may be a typo but here is the info currently shown below. so its either ending 44- or 45-.....
FW: r4.26.1-R-1860948-PROD-83002 and the gui is at App version 3.14.5 25/05/2026 OP Posted Stability Problem
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version x.xx.x 12/06/2026 OP Posted
FW: r4.26.3-R-1923145-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
Last line off the official from EE..... Also is your wifi extender one from EE to match your EE Hub, if so would expect that to get a FW update also, needs to be looked at with the web manager interface if not shown app wise?
Fix problems connecting devices to your Smart Hub Plus or Smart Hub 3's WiFi | Broadband Help | EE
