15-02-2026 10:44 AM - edited 15-02-2026 10:45 AM
Service been down since yesterday on the 1.6 package. There are other posts that are similar and suggest an issue.
3rd party route logs (also no service on the EE hub,logs here don't seem detailed)
2026-02-15T10:27:52Noticeppp[wan_link0] Link: reconnection attempt 27613 in 3 seconds
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: LayerStart
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: state change Stopped --> Starting
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: Down event
2026-02-15T10:27:52Noticeppp[wan_link0] Link: DOWN event
2026-02-15T10:27:52Noticeppp[wan_link0] PPPoE: connection closed
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: LayerFinish
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: state change Stopping --> Stopped
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: rec'd Terminate Ack #91 (Stopping)
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: SendTerminateAck #92
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: rec'd Terminate Request #247 (Stopping)
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: LayerDown
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: SendTerminateReq #91
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: state change Opened --> Stopping
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: parameter negotiation failed
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: authorization failed
2026-02-15T10:27:52Noticeppp[wan_link0] MESG: CHAP authentication failure
2026-02-15T10:27:52Noticeppp[wan_link0] CHAP: rec'd FAILURE #1 len: 31
2026-02-15T10:27:52Noticeppp[wan_link0] CHAP: sending RESPONSE #1 len: 46
2026-02-15T10:27:52Noticeppp[wan_link0] CHAP: Using authname "bthomehub@btbroadband.com"
2026-02-15T10:27:52Noticeppp[wan_link0] Name: "acc-aln2.ra"
2026-02-15T10:27:52Noticeppp[wan_link0] CHAP: rec'd CHALLENGE #1 len: 64
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: LayerUp
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: auth: peer wants CHAP, I want nothing
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: state change Ack-Sent --> Opened
2026-02-15T10:27:52Noticeppp[wan_link0] MAGICNUM 0x32b9ff82
2026-02-15T10:27:52Noticeppp[wan_link0] MRU 1492
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: rec'd Configure Ack #90 (Ack-Sent)
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: SendConfigReq #90
2026-02-15T10:27:52Noticeppp[wan_link0] PROTOCOMP
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: rec'd Configure Reject #89 (Ack-Sent)
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: state change Req-Sent --> Ack-Sent
2026-02-15T10:27:52Noticeppp[wan_link0] MAGICNUM 0x67dd4d35
2026-02-15T10:27:52Noticeppp[wan_link0] AUTHPROTO CHAP MD5
2026-02-15T10:27:52Noticeppp[wan_link0] LCP: SendConfigAck #246
Gpt summary -
EE FTTP down, CHAP authentication failure on both custom router and EE Hub
Broadband dropped this yesterday and will not reconnect.
Openreach ONT lights are normal:
Power green
PON solid green
LOS off
Using both OPNsense and the official EE Smart Hub gives the same result. Smart Hub flashes orange.
PPPoE logs show:
LCP authorization failed
Connecting to access concentrator acc-aln2.ra
Reconnection loop
Username in use: bthomehub@btbroadband.com
So fibre link is up and PPP session reaches EE, but authentication is being rejected.
No recent internal changes to network. Line was working fine previously.
Has anyone seen this recently with EE? Looks like a RADIUS or backend provisioning issue rather than physical line fault.
16-02-2026 09:40 AM
I have to say I’ve not been impressed with this! I appreciate things go wrong and we have outages but being told different reasons and different target resolution dates is quite a shambles.
What’s the true reason for this and what is the realistic resolution dates? I just want to know so I can make arrangements to get me some Internet service from a 5G modem.
I was with Virgin Media before and even though they weren’t great , I never had more than 6hrs outage from them.
will I regret this move!!
16-02-2026 09:46 AM
@Hongsit YES, you will.
16-02-2026 11:40 AM
Happy to report that for me, it’s back up.
16-02-2026 11:47 AM
Just rebooted everything and still down for me - DL3 postcode.
16-02-2026 11:47 AM - edited 16-02-2026 11:49 AM
A good sign the fix is being rolled out hopefully 🤞
Still down here following a reboot of kit. CT11
16-02-2026 12:17 PM
RH19 postcode here
on the 1.6 Gbps package
i'm at work but just been informed by people in the propertly download speeds are 70 Mbps and upload 115 Mbps
full restart of ONT and EE hub a few times....
16-02-2026 12:19 PM
Still down WA3 at 12.18pm
16-02-2026 12:23 PM
Just tried an ONT reset myself, still locked at 35mbps... remind me again why I pay £65 a month for this?!
3 days and counting, where is the communication?
16-02-2026 01:13 PM
@kjw_kjw Would be not many ISP's offering such high speed connections!
16-02-2026 01:30 PM
