sim card not working, the phone sees it but no signal
trackdayguy
The most common explanation for issues such as this, is that your SIM has gone into hibernation.
I'd recommend a read of this EE help article which explains the policy and the means to recover a hibernated SIM.
You may need to call EE C/S to do this, you can do so from anywhere in the world using +44 7953 966250, or +44 800 0798586 using a web-calling app such as Skype.
Hello @trackdayguy
Is this a replacement SIM, or a brand new SIM?
Are you on PAYG or pay-monthly?
Are you in the UK or abroad?
If you could explain a little more about your issue, and how this SIM problem has come about, I'm sure the community can advise.
Thanks for replying to my issue. I live in Canada, so the phone its not used much, I try and remember to send a text every month or so, but don't remember when I last did that. Its a replacement sim. Had the number 30 years. Recently, 2 years ago got moved from Orange.
PAYG
