close
sim card not registering
Profile closed
Not applicable
A neighbour has just got a 4GEE router with sim card but it isnt getting a signal
I've checked the router and know it is working ok as it can see the EE network is available
The sim card is not damaged as I can see all the info on the router (phone number, IMEI etc)
The card is simply not registering on the network
This is a common problem in this area where the mast only provides a 4g signal which therefore means it has to be contract (not PAYG) and phones will only work if they have VoLTE capability
The issue appears to be connected with the mast only using band 20 (800MHz) as everything works ok when we take it into town where there are multiple bands on other masts
(we live miles from anywhere and the mast is the only one accessible)
I've helped several other neighbours to get past this issue by talking directly with EE but am wasting several hours every time before EE simply replicate the setup of my own sim but have had no explanation on the cause
Any idea on the exact cause of this issue?
7 REPLIES 7
James_B
EE Community Manager
Hi @Profile closed,
You shouldn't have to make any settings changes for the router to connect to band 20.
Have you tried the router in different parts of the building to see if connects?
Profile closed
Not applicable
it’s not a reception issue
I know I shouldn’t have to do anything different but it doesn’t work
I've tried it in a phone and a different router and it has the same issue
It’s definitely something to do with the way it’s set up on EE systems
I’d just like to know the cause
Believe me, I’ve helped several people in my area with the exact same issue
James_B
Hi @Profile closed,
Sorry, we can't access individual accounts via the EE Community. Please get in touch with Customer Care for support.
PAYG SIMs do work in a mobile router on the 4G network.
Profile closed
Not applicable
We've managed to resolve the issue following assistance from 2nd line support
The issue was resolved by ensuring that the sim is configured for wifi/4g calling
This setting can only be performed by EE
James_B
Glad you got it sorted @Profile closed
Thanks for the update.
That's fishy! Mobile routers don't do calls anyway! They have no dialler.
