pre order pink galaxy s20 5g
emma732015
Hi
i am looking to order the pink Galaxy s20 5g, however it is saying it's available for preorder then underneath it says it is in stock. I am confused about whether the item is in stock or not?
many thanks
Emma
James_B
EE Community Manager
Hi @emma732015,
I've been able to confirm that it's currently in stock.
Hope this helps.
8 REPLIES 8
Profile closed
Not applicable
Hi @emma732015
Welcome to the EE Community,
I just checked it myself and also seen the same as you the other two colours are in stock to be 100% sure I would ring the sales team on 0800 956 6000 opt 2 opt 1 from 8AM they will have access to reviewing stock levels.
Thanks,
David.
Thank you I will do it tomorrow x
Hi so I called EE but didn't get very far or get my issue solved. I'm worried if I order it that I'm not going to get it for ageZ
James_B
Hi @emma732015,
Did the sales team check if the phone was currently in stock for you?
Hi
No they haven't , when I called I was on hold for over an which hour, is expected, then when I got an answer they said hello then it hung up and I never received a call back.
Emma
James_B
Hi @emma732015,
Hope this helps.
Hi James.
Thank you so much. I didn't want to order it then it not turn up as it's out of stock.
James_B
No problem @emma732015 🙂
