mifi network security key
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-11-2021 09:59 PM
i have a mifi which i have not used for some time and i know i need to top it up. but how do i find a network security key? would that come with a new sim?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-11-2021 01:58 AM
@kjmpde : No, both the admin & WiFi pwds are properties of your mobile router & are usually printed on a label somewhere on it.
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-11-2021 01:58 AM
