ee voicemail
rayboy68
Hi everyone,
Im new her so Hope you're all well and staying safe.
I could do with a bit of help if you would be so kind.
I received a voicemail today but only had my galaxy watch on but was unable to access the voicemail, the watch is new and this is the first time I have used it, I can do everything else but not voicemail, just said that it wasn't set up for it, any suggestions would be greatly appreciated.
Thanks Ray.
7 REPLIES 7
@rayboy68  if it’s possible I have a feeling you need to set up a pin to access your voicemail from any device that is not your phone.    Calling your voicemail by holding down the number 1 key on the phone dial pad will access your voicemail and you’ll have to listen to the options given so you can setup a voicemail pin.
  • call your voicemail (press and hold 1)
  • skip to the main menu by pressing *
  • select option 3 – settings and features menu.
  • select option 3 – change your PIN.
  • enter a new PIN, then press # to save.
Thanks Chris_B that certainly makes sense so I will give it a try, thank you for your input.
I've tried today what Chris_B suggested but it didn't work, just told me I didn't have voicemail activated on my account but obviously thats not true as I have.
Katie_B
Hello @rayboy68
Thanks for letting us know.
Are you aware if the voicemail shows on your phone?
Speak soon,
Katie.
Hi Katie_B
No it doesn't show on my phone when I try to connect to voicemail on my watch.
Sorry for the delayed reply.
James_B
EE Community Manager
Hi @rayboy68,
I've asked our devices team to check if Voicemail is supported on your watch.
I'll get back to you as soon as I get a response.
Thanks James I appreciate that.
Hopefully will be sorted soon.
