close
download v upload
Stepsend36
In the last few days we have been getting download speeds on our 4GEE homerouter (located in log cabin with ponyting antenna attached) of 8.8 mbps and uploads of 23.1mbps, it used to be the other way round.................................................
We have another 4geehome router in the house and the speeds are opposite.....download speeds of 24.3 and upload of 5.54
both routers are by windows and the pc in the log cabin is plugged into the router via ethernet
anyone help ?
Hello @Stepsend36
Have you checked the coverage & status checker for any reported issues in your area?
Select "check network" instead of "check coverage" and you'll load the faults & issues check.
Thanks for that. I have and everything is good. Is that network and connection to 4G is good.
Christopher_G
Hi @Stepsend36
Welcome to the community.
Have you tried restarting the router?
